nah Sigs right, saying it was at a carpark in belco would be sufficient. exact details are basically giving theives the key. and they do watch forums.
e.g on ns.com last night i posted a spoted for a onevia, i said it was in one of the highest streets in chisolm but would not list its name. its just safer that way.
https://www.sau.com.au/forums/topic/30059-spotted/page/133/#findComment-1216317
yea i understand that... but generally....peeps say... spotted blah blah parked outside blah blah... so ...yea....you know.... but aint always mean there gonna be there for the next few weeks..... could be dropping by for some bread and milk....
But i understand what you mean..
https://www.sau.com.au/forums/topic/30059-spotted/page/133/#findComment-1216332
spotted a green volvo....oops sorry, Stagea, at the underground carpark in woden, what were you upto there Jay?
Yeah that green one is only new in town. he's on here known as kowm. we're getting our numbers up in canberra, oh yeah!
https://www.sau.com.au/forums/topic/30059-spotted/page/133/#findComment-1216761
i agree with andrew (skyGTRline) you dont make a spotted thread to then not say where you spotted a car. i do see where everyopne else is coming from but look at the members rides thread... that gives thieves the perfect oppurtunity to find out whats in everyones rides and whats worth thieving and how much money you spent on it etc... i spose you can b careful that it doesnt happen to you but hey you could be paranoid about the food you eat at a restaurant.
as of spotting things today....ive seen nothing, but the day isnt over yet!!
https://www.sau.com.au/forums/topic/30059-spotted/page/133/#findComment-1216936
no worries envisage i reckon it should be fine as his is just a dodgy car with no rear quater panel lol.
also spotted a s1 gunmetal grey 33 about 20 minutes ago turning at the lights in oxley. didnt get a wave as the dude looked to be talking to the gf
https://www.sau.com.au/forums/topic/30059-spotted/page/133/#findComment-1217181
Spotted Silver R33GTR at the lights out of tuggers... pulled up next to ya... cant remember your username..... but i said it then and ill say it now.... man that car is fat... with n "F" also with a "PH"
I tried keeping up when you took off..... i tried.. :P
https://www.sau.com.au/forums/topic/30059-spotted/page/133/#findComment-1217211
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
