Spotted the craziest 33 ever yesterday! Wicked Gold colour, full kit, very low, wheels, loud, drift wing and stickers down the door. Sexy looking blond chick driving!!! It caught my eye just as the sun hit it so I couldnt see properly, plus I was hitting the roundabout in the opposite direction. It might have been the conditions in which I saw it but this thing was wild!
About 5:30 yesterday at the big roundabout on the bottom of lexcen ave. If anyone knows this car let me know where I can see it again!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1277762
The girl works directly opposite me and I see the car every morning while im having my pre-work smoko. Will try and get a pic of it next week on my phone.
I dunno wether it sounds unhealthy or seriously modified... it definately doesnt sound like your average run of the mill RB25 though (to me it sounds like an RB26 with large aftermarket camshafts...)
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1278464
Cheers bro! I just need to see if this thing is as wild as I thought it was! Half a second just wasnt long enough to appreciate what I was looking at! Is it painted "Top Secret" gold? Or something similar? I was set on painting mine Holden green but i'm starting to change my mind!
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1278658
Hey David
are you going out tomorrow night?? I was thinking about going out cruising for a bit
Did adam end up charging you for ya car?
yeah i'll prolly be out cruising tonight somewhere. and yes adam did end up cahrging me extra for fixing the passenger door mechanism. i wasn't all that happy about it, but at least its done now. it was just that it was working fine before i brought it in, and fooked after. he met me half-way for the 3 hours he reckons were spent on it ($90).
d
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1278711
spotted andrew aka skygtrline heading towards "take me to struggle town" :rofl: at about 4:55 :)
realy??? oh...
did i wave.????
Must not of seen you... or i just cant remember...
Spotted Graham again today parked down at tuggers... had a lil squege at your car, but didnt want to look to suss... nice...love the lip on the front...
Also at about 7pm a white R33 with chromies driving into woden, NSW plates.
And me sliding into a pole and wiping out the rear of my car...
HAAA! April fools... : :wassup:
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1278766
I work with her (keeler hardware) wiluna st fyshwick, The blonde Chicks name is Kesha, but its her boyfriend daniel's car. Number plate "YO BABY". wouldnt say heavily modded, but Kesha tells me its a GTR, its got a veilside kit, front mount etc. It stands out but too many stickers i recon.
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1279643
yeh i will try to dont see it around much so see what i can do
I'll take a photo on monday and post it up. :rofl:
Panadl, how come whenever i see you driving around fyshwick your sideways? lol
I saw ur mate filming you one day in tha caldisac off wiluna street, I was in an old white VL 308 Wagon at the time.
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1279649
Ah cool, I work just across the street at Infinite Networks (its in the building with a reflective front window on a 45 degree angle to the street between Paragon and Kell & Rigby).
From everything I have seen, it doesnt look like a GTR (no flared guards unless im not looking close enough).
https://www.sau.com.au/forums/topic/30059-spotted/page/152/#findComment-1280438
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
