hmmm
about 6:10pm at BP in Phillip, silver S2 R33 with a well heeled looking middle aged couple inside, dead stock, puttering along Melrose drive, as it turned into Phillip where the BP is, the bitch nailed it and kept the foot down until I could distinctly hear th rev limited come knocking (It's always the unexpected ones huh)
And seconds later going the other way, gunmetal grey R32 GT-R with 16' BBS wheels
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1381329
spotted a nast accident in Tuggers just on the corner near Tyre Power. From what i could see, 300ZX rear ended by an ugly Buttercup coloured Falcon with chrome hubcaps and smashed into a pole. Not a pretty sight. Didn't look like anyone was hurt, but the funny thing is it took the cops over 20 minutes to get there and they are like 2 minutes up the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1381530
spotted what looked to be a pretty bad accident at chisholm roundabout. Looked like the car either went to quick through and cleaned up a light pole ??? well possibly the worst thing is i had a quick glance and it looked like a skyline :P i could be wrong though it was only a really quick look
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1382223
Correct, was a blue skyline wrapped around a pole... hope the driver and any passangers got out ok.
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1382234
god damn it :D it will so be in the news about how skyline are unsafe. anyways as amaru said hope he is all good i thought it was a silver one with black decals on the bonnet but yea i got nothing i only had a quick glimpse. must have been a fair hit as the light poll waso n the ground
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1382631
the light poles are designed to fall over if they are hit. Do less damage that way with regard to passengers I think. It also disconnects from the power source too. I know I hit one many a year ago.
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1382831
Spotted a suicidal 'roo this morning on Lady Denman Drive, right out front of the botanic gardens, the crazy guy was heading straight in front of me, so i accelerated and he just clipped me on the right rear quarter, left some dirt/dust/scratches and a nice dent above the wheel, bastard
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1383200
spotted what looked like a small altercation between a blue R31 and an Xtrail with a trailer at the roundabout on Athlon/Sulwood Dr this arvo.
Neither looked badly damaged?? dunno couldnt really see..
looked like it had just happened as they were both stopped & wondering what to do, people were driving around them, and then they moved out the way.
https://www.sau.com.au/forums/topic/30059-spotted/page/172/#findComment-1384264
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
