Spotted!!
Shell
Spotted Andrew (Veilside) on the side of the parkway this arvo with another car, hope you weren't in any trouble. also passed another maroon R33 going the other just after and a black R33 in Aranda. then spotted a black R32 outside the labour club in belco.
Spotted Andrew (Veilside) on the side of the parkway this arvo with another car, hope you weren't in any trouble. .
ha i knew someone would have seen me, That other car was an unmarked cop car......and yes i was in trouble, it will be adding up to well over $500
I'll be contesting it in court though.
yeah it was over 2 years ago now, it was 125 in an 80 zone (down drakeford) in my little lancer.
Im not going to go to talk about this one on the forums, its nothing like as bad as my only other ticket but i dont want to discuss it on the forums.
Im happy to have a chat to ya'll on tuesday and tonight etc.
Indecent exposure? :confused:
Keep seeing a white R33 GTS-t in my street, GTR kit. Looks pretty good. followed me to work this morning but i don't think the owner is on the forums...
GunMetalR33, spotted you (I think!!!) - leaving Kambah shops (at the lights) Saturday around 7.30pm.
Spotted last Friday: 2x silver R33's at Woden (in carparks)
Black R34...going over Athlon Dr around 5pm i think.
Yea, I think that was me. I have new gold mags now ;)
This is weird, I dont get spotted for 2 years or so then BAM, 2 spies in 3 days (its good to be seen) :D
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
