spotted a veeerrryy nice Midnight purple R33 GTR Vspec2 today on streeton drive, it caught up behind me then as we turned at the lights he pulled next to me and gave me a wave (i know him from somewhere i think he lives accross the road) anyway, i had to turn so i couldn't play, so he flawed it past me and took off like a bat out of hell (must have some serious work done) or as Jayce would say "some serious get up and boogie!" twas very hot! nice plates too!- VSPEC 2
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1492767
nice spot, but they dont exist
spotted Jayce and Erica at Pheasants nest servo on the way out of sydney, they were at a subie cruise, i was cruising with a hot rod, pure sex that car
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1493959
spotted a white R33 parked next to me in the Canberra Centre carpark on Sunday when I came back to my car...nice looking car...had a nice body kit and red snap on seat covers, that's all I can remember..
oh and a 180 and WRX making loud psssst noises thru every level of the carpark until they got to the level I was on, and then they parked nearby :lol:
also saw another white R33 on my way home (just before Parliament House)....gave a wave, got a REALLY weird look back like he couldn't work out why I was waving...hmmm or maybe the sun was blinding him...i dunno...but I'm sick of waving and just getting strange looks!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1496062
Saw a white series 1 33 in Weetangera with some nasty looking damage on the front and down the side... It occurs to me I don't really see many lines anymore :( I used to see bloody skylines all the time when I was driving around in my super awesome 626 XD
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1498556
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
