spotted a veeerrryy nice Midnight purple R33 GTR Vspec2 today on streeton drive, it caught up behind me then as we turned at the lights he pulled next to me and gave me a wave (i know him from somewhere i think he lives accross the road) anyway, i had to turn so i couldn't play, so he flawed it past me and took off like a bat out of hell (must have some serious work done) or as Jayce would say "some serious get up and boogie!" twas very hot! nice plates too!- VSPEC 2
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1492767
nice spot, but they dont exist
spotted Jayce and Erica at Pheasants nest servo on the way out of sydney, they were at a subie cruise, i was cruising with a hot rod, pure sex that car
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1493959
spotted a white R33 parked next to me in the Canberra Centre carpark on Sunday when I came back to my car...nice looking car...had a nice body kit and red snap on seat covers, that's all I can remember..
oh and a 180 and WRX making loud psssst noises thru every level of the carpark until they got to the level I was on, and then they parked nearby :lol:
also saw another white R33 on my way home (just before Parliament House)....gave a wave, got a REALLY weird look back like he couldn't work out why I was waving...hmmm or maybe the sun was blinding him...i dunno...but I'm sick of waving and just getting strange looks!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1496062
Saw a white series 1 33 in Weetangera with some nasty looking damage on the front and down the side... It occurs to me I don't really see many lines anymore :( I used to see bloody skylines all the time when I was driving around in my super awesome 626 XD
https://www.sau.com.au/forums/topic/30059-spotted/page/191/#findComment-1498556
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
