Spotted!!
Shell
spotted a burgandy r32 in civic around lunch time.
w00t spotted again ;)
Didn't pass roadworthy today, suspension has to be changed etc :blink:
Oh well, at least I have the choice to get coilovers now :(
Spotted a grey R34 GTT in Belconnen this morning, and a Black S1 R33 in the city around lunchtime.
Nath
Edited by NathR32
spotted a black s1 behind me as i turned out of the carpark about 45 minutes ago but he turned the other way when i went straight.
That was probably Sleeman, was it a stockers S1??
spotted a wine R32 GTSt going through civic, had it's fuel cap open, loser.
hehe
That wasn't me today, however I did fill up with petrol this morning, I think I closed my fuel cap lol :P . I was working at Fyshwick all day. I haven't seen another maroon R32 in Canberra, but have heard there is another one floating around.
Spotted a slightly modded white S1 R33 with no wing on Gladstone St around 10am and also another white S1 R33, stock, outside Autobarn Fyshwick in the afternoon. Talked to a guy in a white 4 dr R32 and told him to join up on here also.
Nath
Edited by NathR32
Saw a wine red R33 in traffic next to me coming into Woden, briefly pulled next to me, exchanged waves then we disappeared in traffic :P
Haha damn you beat me to it, i was gonna post up that i saw you, i saw you from miles away and chased you down, thats why i made sure i caught up and gave a wave, i would have gone the same way home as you but needed petrol in Phillip, car is looking hot as always :D
That reminds me, i spotted Long in his gunmetal R32 GTR the other day coming out of the dickson tradies, i was in the gunmetal R33 GTSt
Hi Terminal, haven't been on for awhile... the gtr's been off the road... had to get a few things fixed and I was driving a hire car for awhile, you don't know what your missing till you drive a complete s**tbox.. anyway glad to be in the gtr again, will try and make a friday soon
btw, did you get your 2nd dan?
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
