Spotted!!
Shell
yeah deffinetly some nice machines getting around! cant wait til mines gets out there :) That RH9 is a damn fine machine, and wasn't there a Red R32 that was getting around aswell that raced that umm RX3 or sumthin?
Edited by R31_silo2
wow! no not top secret. from what i know about the car its been built in australia by people that know a thing or 2 about fast gtrs... hehe. the camcovers should signify something built with lots of... umm... jun bits perhaps??!! :)
what a work of art!
i've been waiting to meet this guy for how long now!? i remember when i was working at kingston hi-fi seeing this car (about 2 years ago or so??) and then it just dissapeared! i've heard so much about this car i can't believe its actually on the road and running (finally!)
i'll be the first here to call reserve shotgun rights when its done its time doing the whole running in thing.
david
Was a gunmetal R32 and he sold it and now owns RH9 :)
Slightly off topic: I rate DJ Hatton's avatar-Silent Bob rocks! For those that don't know,check out the movies Clerks,Mallrats,Chasing Amy,Dogma and Jay and Silent Bob Strike Back...
Bloody BMW drivers!!!!! :P
was driving on the way to work today, when i came across a car in the right hand lane, doing about 65kph. so i happily decided to move into the left hand lane to pass it, so i did. then i happen to come across another one and did the same thing, as we were pulling up to a set of lights (about 100m away!). lights go green, i take off (wasn't racing, but was moving quicker than everyone else), then from no where, this silver BMW decides to sit on my arse. so i speed up a little, but he doen't move. coming into the big roundabout at woden, i get a little tired of this knob, and gun it through there, loosing him. then he comes back along the straight, so he sits on my arse again. im passing a truck, so i cant move over, when i do, he races up beside me and shakes his head and makes a fist at me??? as if to say "you bloody hoon"! What The F*ck?!?! he was sitting on my arse and causing road rage when it was totally uncalled for, and im at fault??? that just really pissed me off.... im about to punch the computer screen it makes me so angry!!! aaaarrrrrrrrgggggghhhhhhh!!!!!!!!!!! :):):angry::angry:
*end rant and rage*
true i already have clerkys, mallrats chasing amy and jay and silent bob strike back great movies
Exhanged waves with someone in a white R32 Gts-t at the traffic lights at the back of Belco Mall.
Also spotted various coloured R33's and a stock R34 sedan.
Edited by NathR32
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
