:blink:  A tissue - Shhh ! I dont admit to luving my ride in that way!
uh huh mm humm... and i'm sure that "really" was excess polish you missed when buffing the bonnet...
heh. on a more serious note, any action happening with the car yet? i'd love to see the beastie back on the road...
d
https://www.sau.com.au/forums/topic/30059-spotted/page/217/#findComment-1637343
Spotted (and continue to spot) andrews old "Veilside R33". I will try and remember your actual name so i can use it. Yesterday it was at the "G", how did you get the car down in to the underground park? It must have a decent ride height clearance to make it past the mount everest style down ramp? Mine would never make it. Lucky i was in the taxi (commodore) and it wasnt a issue.
https://www.sau.com.au/forums/topic/30059-spotted/page/217/#findComment-1638132
yesterday spotted terminal, going past going into civic in the morning, heading off to work?
today spotted a white r33 with chromies and a black R32, i think ive briefly met you 2 guys before one friday night at the museum (and im pretty sure your on SAU). spotted you two on northbourne ave today round 3.15pm. i was in my friend michelle's excel, she was really excited cause she just got it and wanted to go cruising, sorry if it looked sus... :( also spotted anakha in the woden carpark today round 4pm on the 1st floor. im pretty sure it was you, had a steering wheel lock.
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/30059-spotted/page/217/#findComment-1639389
saw a black 32 gtst this morning with white wheels and very dark (like black) window tint. it was heading southbound along yamba dr, going past the hospital. i didnt bother waving cause i couldnt even see the driver!!! no offence.....
https://www.sau.com.au/forums/topic/30059-spotted/page/217/#findComment-1640514
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
