Spotted!!
Shell
Spotted a white r33 gtst on 18" chrome rims.. behind me then next to me at the next set of traffic lights just past new woden police station... anyone off here?? I probably sounded a little rediculous trying to drive it... just got a new heavy duty clutch:P
Dayne
shat myself today. was at lights going thru the city today, at the lights opn northbourne intersecting london cct, white 34 GTR v-spec, black plates. this dude has got one of those oversized custom black plastic plates, with an apexi logo under his rear rego, looked farken hot
got a photo of it from the car, which i might post later
:rolleyes::);)
Spotted a MEGA FAT woman throwing her Hyundai Excel car door open onto my Skyline. It's not a big scratch, it'll buff out ok.
But she denied knowing anything about it! My alarm even went off!! Then she goes, "Well is there any damage?" and I said "well there's a scratch" knowing full well there's f&ck all I can do about it.
Then she grabbed her pizza and waddled back to the car and drove off!
;):angry::angry:
:D  :angry:  :angry:
:angry:  :angry:  :angry:
should have ticked the 'Harpoon' option when you ordered your car.
:D  :angry:  :angry:
hahaha. i love it how its so easy to stereotype :) but yes, "waddle" is kinda amusing.
hope it buffs out man. par carks are hazards of the most evil variety. especially thems hyundai eggshells. anyone driving such a horrible car really shouldn't show any respect for it. i drove one once and i'm still suffering from PTSD.
d
Spotted tonight a dark blue 32 GTR in Gilmore
Also just now after i pulled into my drive way.. i heard a car come up the street... quiet street.. a very sus lookin Honda Accord driving past my house checking out my car...
Lil bit scary.
spotted. white 33 in civs tonight. new skyline owner in canberra. we might see him out and about on the forums (i think he's just devouring the huge amount of info there is on here before he posts! :()
also, spotted a rs2000 esky, pale yellow 300 and a silver 33gtst cruising about. me and my mate had a bit of a play with them. gave wave/toot to/from the line.
and yeah, andy that sux when you see dodgy stuff like that. its happened at mine a few times and its really bloody disconcerting!!!!
d
Also Shell in belco on friday night, spotted a Silver 32 with Vertex kit... Chick driver.. i think your on the fourms..
Hey yeh that was me.. saw u 2.. thats the day i bought the baby :) my car looks a bit different now, 18" chrome and fat exhaust :( your car looks heaps neat.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
