Gunmetal R32 GTR heading north on Cwlth Ave today around lunchtime, nice car.
thanks scooby, that would've been me heading to work..
spotted today, maroon or red r32gtr on northbourne...sorry Im a bit colour blind... very neat and the mags looked awesome
also spotted on saturday, viper at the soundoff at jb in woden
https://www.sau.com.au/forums/topic/30059-spotted/page/233/#findComment-1698939
'mines at some place in fyswick'
'Spotted Leigh's car at said place in Fyshwick, mine's there too!'
'thats funny is ben doing work on yours too or is it the un-named place :)'
very cloak and dagger.
'Go to a warehouse in Fyshwick. Be careful. There you will meet Tuna er Tuner, and he will introduce you to the killer, Watts. Be careful if there is someone from China called Hybrid, he may be a copy. Trust no one and Greddy to split if you feel too much heat. Advance as much as you can but back off so you don't get knocked. If you're in trouble, Pon cam not help until later and neither cam Wheel as they've been told to strut some bar. If it all goes bad then just think quick, shift.'
OK so I'm bored.
https://www.sau.com.au/forums/topic/30059-spotted/page/233/#findComment-1700902
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
