looks like i've been hearing bullshit shell :P
detomaso pantera, i got the ford thing right though!
http://www5a.biglobe.ne.jp/~supercar/CARS/...aso_pantera.jpg
That car right there is NUTS!
A mate told me about it during one of the formals.. Its apparently got a rear mounted 351 V8 engine, with 4 carbys (1 carby for every 2 cylinders for those playing along at home). Its also a 4V engine, which was explained to me as having 4 valves per cylinder, as apposed to 2 valves in the ordinary 351. Because its rear mounted, it creates an amazing amount of power... and noise...
I just want one.
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786065
that thing is always at chisholm shops...blue/grey two tone wit ugly rims n kit and a rexy scopp :)
spotted long on isabella drive today around 10:30ish...dude thoise rims look like chromies now...nice n shiney (you got them cleaned yeah?)
yeah that was me, I had only just washed the car..Im not really into chromies but yeah they look heaps better
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786187
Spotted some FAG*OT in a commonwhore with his mates, cut me me off, then proceed to blast their horn at me after cutting me off, then without any other warning, giving me the finger constantly over the next 30 seconds! MOTHER FUC*ING FAG*OT!!!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786618
Either way, all the skylines looked very tight, specially yours steve and another wine red r33 with a drift style wing. Are your front gaurds custom steve? the whole kit looked real nice, and different too?
Dayne
yeah wine red was me was meant to have the same gaurds as steve but ran out of cashis after some much needed panel beating like my car looking nice and sleek anywayz
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1786856
looks like i've been hearing bullshit shell :angry:
that's the one!!!!!!!!
http://www.panteracars.com/mont2002a13.jpg
this is just like the arse end that I saw....badges are kinda obvious now I know what it is!!
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1787882
I just want one.
they are a great looking car, 4V refers to the design of the head - the intake port has a greater volume than the 2V. not sure anyone makes a 4 valve head for the 351. came standard with a 4bbl, common set up is to use downdraft carbies like moffat had on the mustang and the falcons for a while. looks truly amazing.
a friend had one, you could just get a coke can sideways under the rear cradle.
de tomaso also made the mangusta, another great looking wedge style.
http://www.motorbase.com/profiles/vehicle/...64;p=1126634563
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1791708
Saw a white R32 with black rims going down Mort Street in Civic. Saw from my work window :D I think he stopped for maccas too.
And while out at Ed's today, saw an awesome looking R33 GTR with paint that looked black from afar but was actually very deep purple up close... Ed was about to put in a RB26DETT which I saw at various stages at Ed's while making a few trips out there over the past few weeks. Swap ya for mine :O
https://www.sau.com.au/forums/topic/30059-spotted/page/252/#findComment-1794312
    • My plan is to go the pink option. But still add the 4th fitting near the oil cap and just cap it off for now.  That way I can add 2 extra to the sump and have 4 dedicated breathers/drains if I ever remove the sump for any reason.
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
