Gunmetal R32 GTS 4 door on Melrose Drive this morning about 7:fiddy
And a piece of comedy - I was sitting on London Circuit about 8am waiting for the lights at Northbourne to change, and what should putter past me but a late 80's white Porsche 911, driver's seat jammed right up to the steering wheel and a little old lady barely able to see above the dashboard :D
https://www.sau.com.au/forums/topic/30059-spotted/page/270/#findComment-1917596
putter past me
she hosed you???? :P
https://www.sau.com.au/forums/topic/30059-spotted/page/270/#findComment-1917751
putter past me
hah, nah, turned across the lights I was waiting at actually
Would be interesting to have an acceleration comparison with one of those older 911's though.....
I think I spoted Bluprint on the Monaro hwy 2 days ago. I was on the other side turning left off Long gully Rd. I could be wrong tho!
Nope, wasn't me
Probably R31DET, our cars look pretty much identical from a distance
https://www.sau.com.au/forums/topic/30059-spotted/page/270/#findComment-1918560
hey guys,
saw the blue r34 gtr today, i see it almost everyday round woden area but today saw it on the way dickson.
Driver was really drivin it slow. stopped at the lights, i was behind him and he was lined up with an S2000 i thought there was gonna be a run for sure. s2000 went but r34 just drove slowly, i wanted to shout out :make that s2000 eat dust but the exhaust in the friggin r34 was so loud that he probly wont hear me - lol
https://www.sau.com.au/forums/topic/30059-spotted/page/270/#findComment-1918806
1x white R33 goin down Belconnen Way this morning about 8.30, doing the same thing as me - trying to find his way through the slowpokes! Turned off at the hospital turn off (I think). Think I met u at the recent dyno day, I had a silver R33. Waved, but nothin (that I saw anyway) :)
https://www.sau.com.au/forums/topic/30059-spotted/page/270/#findComment-1919685
spotted a black R32 on Drakeford tonite on the way home (around midnight)... thought it might have been supafly?? not sure - it was dark and raining  :)
Nah, not me, sorry!
spotted a coulpe todat, but cant remember where/what etc...
https://www.sau.com.au/forums/topic/30059-spotted/page/270/#findComment-1919755
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
