Saw a white 32 at the same party i was at, on the 27th.. realised it was shredder.
Me and shredder met ages ago.. small world. Hi shreds.
"why have you got a dead whale on your shirt?"
hey karl with a k! its actually a slug on my shirt, or a hill with dead trees. ugh. idiots.
https://www.sau.com.au/forums/topic/30059-spotted/page/366/#findComment-2782545
I seem to be getting a few more spots these days :) yeah SL33KY is my car... I am up in Sydney at the moment and got two waves through Penrith and a beep from a gunmetal R33 and a black 34, seems as though the Sydney SAU people are quite welcoming! Going to head out tonight to mingle, heard they're out a bit Friday and Saturday nights!
https://www.sau.com.au/forums/topic/30059-spotted/page/366/#findComment-2782931
spotted Mark on adelaide ave this morn.
Also spotted the top alcohol, top fuel, top doorslammer and supercharged outlaw drag cars in sydney on boxing day. those things are amazing to watch/feel going down the dragstrip! even saw one blow the engine at half track and still running a 5.5 sec pass!
https://www.sau.com.au/forums/topic/30059-spotted/page/366/#findComment-2786776
Spotted you the other night on and near the Kings bridge heading out to Manuka/Kingston region.
Nice sideskirts :)
https://www.sau.com.au/forums/topic/30059-spotted/page/366/#findComment-2788445
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
