on sunday i think i also spotted SHELL at brand depot but she walked right past me as i was saying hello so im not sure lol.
:( OMG! I'm so sorry!! I was there, so it must have been me, but I didn't see you! I swear I must walk around in a daze sometimes lol
Was it inside a shop or outside in the carpark or what?
I feel bad now!
https://www.sau.com.au/forums/topic/30059-spotted/page/478/#findComment-3797066
follwed a blue 32 along moreshead dr yesty, just near the airport, but was in a work van, so didnt bother waving etc..
last night, in my 32, had a car right up my arse going over the speedhumps in manuka, had a lil sign on top, thought it said taxi, was just about to flip them off, had another look and it actually said afp, they had a mad look at us too when we got to the stop signs and went different ways
https://www.sau.com.au/forums/topic/30059-spotted/page/478/#findComment-3797617
Saw silver 34GTT with white wheels past ANU at 4 this arvo. Think it may have been Michele??
Yep that twas moi, Steddy will be jealous now cos thats the second time his car's been spotted and he wasn't driving it :laugh:
https://www.sau.com.au/forums/topic/30059-spotted/page/478/#findComment-3798288
nice GTR Kirstie! you and Michele can cruise together in your QLD rego silver R32 GTRs hehe
There is a stickied thread to post pics of your ride but in here is cool too :banana:
you should bring it out to the museum tonight! I might even make an appearance too! mebe.....
https://www.sau.com.au/forums/topic/30059-spotted/page/478/#findComment-3803773
Yeah Kirstie, your car is HOT HOT HOT, even down to the Qld rego, we're almost twins :banana:
So tell us more Kirstie, did you move here from Qld or buy the car from up there?
https://www.sau.com.au/forums/topic/30059-spotted/page/478/#findComment-3803838
Well I did move down here from Qld... but that was 7 years ago! No I bought this in Sydney, and he had bought it from Qld- so those photo's are from last year. I haven't taken any new ones as yet, but it still looks the same on the outside.
Thanks for all the great comments - love hearing good stuff bout my toy!
https://www.sau.com.au/forums/topic/30059-spotted/page/478/#findComment-3804771
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
