heh i heard about that, as soon as they said that corner I knew it had to be MM!
I wonder how the hell it happened :D
I think these photos might give some of the story away as you get to the end of the slideshow...
http://www.canberratimes.com.au/slideshowplayer.aspx?id=3010
https://www.sau.com.au/forums/topic/30059-spotted/page/498/#findComment-4080468
Spotted a ute the just yesterday with r32 coupe lights stuck below the tray. Seemed like he was in a massive rush zooming away along tharwa drive about 12am.
haha, seen that a few times arounds Tuggers area, looks weird
https://www.sau.com.au/forums/topic/30059-spotted/page/498/#findComment-4082713
Sunday? Was that you in the soarer?
My car was being a jerk, was just before i did the points and it was constantly stalling so i had to watch the tacho while pumping the accelerator (too much and it backfired through the carby, too little and it stalled). Glanced up for a second and 2 people in a soarer were staring at me.
Points fixed now though, all is well in the universe
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/498/#findComment-4084200
i saw one of the blue r34 gtrs this arvo in fyshwick and followed it for a little while as well as a yellow series 6 7 or 8 (can't tell the difference) rx-7
gtr flashed as i was waiting to come out of bdl, very nice looking car
yup that was me and my bro! lol!
https://www.sau.com.au/forums/topic/30059-spotted/page/498/#findComment-4086944
yeh that was me i was drivin my friends car
https://www.sau.com.au/forums/topic/30059-spotted/page/498/#findComment-4087383
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
