I have a brand new MetalCat from Trojan on mine (about 2 months old) so I hope it lasts longer than a year......
I know Ben! Mufflers are just going nuts! Will be interesting to see what happens tomorrow at Powatone. Ian is away so it is all up to John to do a good job for me. I was hoping to get a twin 3" tip but i may have to settle for only a single 3" slash cut.
Ex!$t3nZ - I did see your car yesterday mate. It was up on the hoist when I was there. I had to take a couple of looks at it. So not used to seeing a 'Toyota Camry' like that.
https://www.sau.com.au/forums/topic/30059-spotted/page/518/#findComment-4259386
Spotted a White R33 heading along Hindmarsh towards Fyshwick at lunch time. Also a White R33 with a large bodykit on it in Fyshwick on my way to Harris Tech.
(Car's booked in tomoz to get my two new mufflers sorted, yay, hope it will be quiet enough for the police but loud enough for me)
i work just down the road from harris tech, and my line would have been there, mind you i park up the driveway.
also i saw sl33py on southern cross drive at about 6:20pm tonight, i waved but you weren't looking at me, i was heading the other way
https://www.sau.com.au/forums/topic/30059-spotted/page/518/#findComment-4259430
Delayed 'spotted': riding home on my .45 kilowatt set of wheels, I heard the unmistakable noise of a boosted RB. Spun around to see one of my fave gunmetal grey GT-R 32's drive past onto Dairy Flat Road. Waved to owner, got a wave back: suprised he recognised me in my riding kit!
Also spotted (today) a silver 32 GTR, in VERY neat trim, turning up a street in the upper areas of Jerrabomberra. Are you on here, Mr. GT-R owner?
https://www.sau.com.au/forums/topic/30059-spotted/page/518/#findComment-4262882
spotted white R33 with black wing leaving Tuggers past cop shop (automatic)
gunmetal R33 with some kind of shiny rims in Tuggers KFC drive thru
silver series 2 R33 going into Tuggers (near skate park)
black R33 turning into Kambah on Learmonth Dr
all around 7.30-8pm tonight
https://www.sau.com.au/forums/topic/30059-spotted/page/518/#findComment-4264267
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
