Spotted!!
Shell
HAHAHAHAHA well it would have been pissed when I'd done cleaning the inside and peeled it off then wouldn't I?!
rofl thanks Shell, only emphasising the subject of my recent PM. Well at least this makes things easier.
it's all good stoopid :(
take "back" off, put on OUTSIDE of window, carefully peel off "front"
HTH
oh and take pics so the whole of SAU can see how crooked you got it haha
Spotted white 33 turning left out of clift onto johnson this arvo, got a nod gave a wave ;)
also shell, just for you
(note: the top-left corner of the rubber seal for the windscreen is gone, so it might look crooked.
Can I has a cookie?
also, take note of the horrible condition of the paint on my roof: not my fault :(
Edited by Trozzle
ahhh haha fair enough then :P yeah it's true, it's a shit corner...especially turning right out of clift. it's all bumpy uneven crap tarmac, and like no1 going either direction on johnson ever bothers indicating...
Hey Trozzle, twas my white 33 being dirty as (refraining from washing it until after the skidpan day)...
I wasn't sure you were going to wave since we were both turning in on a terrible corner for traffic.
wooooo! what were you in Jeno??
TiTAN, you no longer exist in my world *insert a talk to the hand smilie*
Troy!! You got it straight!! :P
You can has a cookie!!
Welcome to SAU Scott! :P
mmm R34GTR noice :):(
hopefully we'll spot you around and add you to the thread... what colour is it? Any mods?
Its Sky blue only mods is exhaust and intercooler.
Wanting to put it on the Dyno to see what the car does, Are you guys going to do a Dyno day soon lol
Spotted my skyline without window tint *(GAY) ... rego didn't seem to like 18% sides and 6% rear window very much ...
Anyone cruising tonight ?
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
