Spotted!!
Shell
saw Kat yesterday at autotech well i think it was you i pulled up in the grey R33 at around 5ish
Haha yeah that was me, we both had that "hmmm I think I know who that is" look :)
spotted a silver R33 with red front bar...cruised from Fyshwick to Mawson....I did wave back a couple of times, not sure if you guys saw!
I saw that one the other day... Can't remember when/where so I didn't post it :)
Spotted a blue series 6-8 looking RX7 that managed to slam a lightpole going onto gunghalin drive extension today cops had it all blocked off ...
the pole came down on the rx7 aswell ...
pretty sure those big metal light poles are worth something like $80,000 or something so it was quite a costly crash
there not cheap! but no way 80K... the stylish ones that we installed in section 84 in civic (new canberra center) were around 14K per pole, with fittings...
sure hope its insured anyway!!!
really sux to hear a nice car coming unstuck like that!
Edited by Randon_I_Am
spotted really tidy white 33 parked next to me just now, nsw plates. And a maroon s1 33 not too far in front of me lol
saw a maroon 33 with twin tip exhaust (not the stock) hume to gordon and wondering if i was the white 33 you saw cause i'm armed with the yellow and black plates ...
Haha yeah that was me, we both had that "hmmm I think I know who that is" look :P
ha ha ha yeah ah well maybe next time lol just about to install an apex-i boost controller and talking to ed about getting it dyno tuned again
clean Maroon R33 series 2 wearing P plates, front mount and Trojan sticker on the rear quarter window driving near Reid CIT this morning
that was me its the cleanest its been in 6 months hahahaha took me long enough to get spotted, where were you?
Edited by Greekos
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
