Spotted!!
Shell
Saw a Bayside 34 down the end of Deamer in Richo, pretty sure was GTR, though I was trying to hit the horn lightly enough to say "hi" without hitting enough to say "f**kER" you know? yeahhhhh
spotted a pearl white GTS4 yesterday arvo in nothrbourn i waved as i went past even tooted your a snob jks
spotted a dark green R33 today on markus clark near hobart pl i nodded as i walked in front of your car nice wheels
:banana:
SUNDAY
Spotted a white 33 coming down alkman drive going onto Ginninderra drive at around 4:30 THEN 10 minutes later
Spotted another white 33 coming from Ginninderra drive going down alkman towards maccas
Gave a wave to both, and received a wave from both. I was the white 33 with the 400R front bar and the white volks
MONDAY
Spotted a black r32 GTR going down northbourne ave at around 5:10
TUESDAY
Spotted a Maroon 33 with a S1 wing driving along side me on parkes way at around 8:50 in the morning (tried waving, but whoever it was wasn't looking)
Spotted another maroon 33 about 5 minutes later parked with someone in it next to the hotels/apartments on Edinburgh ave
Spotted that night at around 10:00, what i think was GTRkat in her white 32. i was turning right onto hayden drive. you were turning left onto belconnen way. I gave a wave, not sure if i saw one back.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
