Spotted an R32 GTR past theodore onto the monaro this morning. very nice!
Spotted two maroon r33's yesterday on the monaro, one s2 turning off the Queanbo and a s1 behind me most of the monaro (I was in my sis's pulsar - which i forgot to take the P plates off by the way....)
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787133
JD travelling in style to work this morning. I was in such a daze this morning, saw the waving and my mind said yep, JD, wave back... My hand took an extra minute to react...
You went through the lights at Theodore while I was waiting to turn, and it only took me about 5 K's to catch up :D
The old diesel ute has been called many things (especially the time it broke down halfway up the Clyde), but stylish isn't one of them.....
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787393
You went through the lights at Theodore while I was waiting to turn, and it only took me about 5 K's to catch up :)
Since I drive like a grandma to work, I thought you would have caught me a lot sooner than that! It's always an entertaining scenario in the morning when I have people go flying past me at warp 10 in their Kia's only to stop at the roundabout and then the lights where we turn off..
Haha, poor ute. C'mon, how is it not soooo much more stylish than a GTR, sheesh...
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4787473
I was stealth in the Audi. Had dropped my car off at Inline and in a daze my husband turned instead of going straight when we were leaving Qbn so slight detour lol.
Nice pile of tyres at Inline too Reece. Pity they're not the same size as mine I mighta slipped Chris a $50 to accidentally mix them up ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4791290
Spotted Yellow 34 right out the front of erindale leisure centre as I drove past blinding them no doubt.
Also, some piece of shit (pardon the language) thinking he's f**king funny spitting on my car as he drives beside me in traffic coming down erindale drive - HAHA f**kWIT DIDN'T EXPECT ME TO SEE YOU DO IT HUH? BET YOU DIDN'T EXPECT ME TO GET YOUR PLATES AND MAKE/MODEL EITHER?
Good work to the above dipshit, you'll get your own.
https://www.sau.com.au/forums/topic/30059-spotted/page/577/#findComment-4792380
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
    • Tapin,    So got mine up and realize a few things. First was my slave line doesn’t reach the other side, so I have to get a longer hose made. I want to ask did you have to extend your wires for the CD009 sensors? One on the driver side(right side of car looking at the car from the rear) and one on the passenger side( the left side of car from rear). And do you know what those two sensors are respectively? I know it’s not Speedo since we talked on this already. And I may have to separate the trans again to swap out throw out bearing. We will see. Did you run your RB slave cylinder? I know you cracked your original but replaced it with a nismo. But wasn’t sure if you bought the one designed for the CD009 or not. Thanks
