the what moving? Inside joke? lol
no inside joke at all.
the red bridge outside the belconnen mall that links the mall to lathlain street (now the bus interchange) is being moved closer to the immigration building to make way for the expanding mall
i figured that Bluprint's post had nothing to do with skylines so i thought i might post one as well
Edited by Ex!$t3nZ
https://www.sau.com.au/forums/topic/30059-spotted/page/580/#findComment-4805854
Spotted a blue R32 GTR (that Calsonic blue colour) in Queanbeyan the other day, someone on here used to own it i think? Looks like it's running really rich, one side of the bumper was practically black and it was blowing smoke too. Didn't look too healthy.
Also a white R34 GTT in Queanbehole a week or two ago, owner waved so think it was someone on here.
https://www.sau.com.au/forums/topic/30059-spotted/page/580/#findComment-4810087
saw GTR kat on monaro highway this arvo in the audi... i was in melly's car (bright pink R33 lol)
Hehe yeah we spotted ya too! Hard not to spot that car!
Had a white R33 driving behind me later on the Monaro highway but I was in the GTR this time.
https://www.sau.com.au/forums/topic/30059-spotted/page/580/#findComment-4815018
Drove alongside a mint looking R30 with nice konig wheels today in Quangers. Was an older guy driving it.
where in the world is Quangers in english speaking terms if its in canberra it may have been old bill the tow truck driver wears glasses and has white old guy hair
https://www.sau.com.au/forums/topic/30059-spotted/page/580/#findComment-4815175
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
