Spotted JD this morning in the V Spec... You drove past me but don't think you recognized the new daily driver.
I thought that was you in the white sedan and was nearly going to lean on the horn, but there was a commodore between us which may have been a bogan transporter, so I didn't. :P
So, what is this new beast? I didn't get a good look.
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4815881
Spotted 2 guys on the manaro heading fyshwick way, one in a white commo ute, and the other was some chrysler suv thing, seemed like they were racing.... they were weaving in and of cars and using the side walls, was crazy, they were prob going over 150 in the 80 zone. Very fishy.....
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4815895
Haha, i did notice the possible bogan transporter... You would have been stuck at the lights with them getting out of the car.....
The new beast is a '93 Subaru Liberty Heritage Auto.. Ruff on the outside but drives smooth as. I needed something that would allow me to park in Civic and manuka without worry of theft etc.. As in, I'd still be highly concerned about it being taken, but its better it than the 33.
Edited by sfrizza
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4815920
wtf when I'm not in the 33, I see heaps of other skylines, but once I sit inside her, no1 is around to be seen >.<
Mustn't see others/be seen when I'm in my own little world...hahaha considering how often I'm on my way to Fyshwick every morning.
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4816013
Haha that's what happens to me too. The audi gets spotted much more between here and CC than the GTR does :)
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4816065
haha, what kinda wheels u got?
They looked like some kind of 5 spoke chromes from the distance I was at, assumed it may have been u coz I can't think of anyone else with a white 33, other than Reece (not turismo)
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4818311
MMmm, my rims aren't chrome apart from the lip/dish
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4818319
spotted a white R33 on Long Gully Rd about 4pm... gave a wave not sure if they saw
and a silver R33 stopped outside the car yards in Phillip opposite Marist... guy in drivers seat, blonde girl outside car on passenger side.
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4821281
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
