Spotted!!
Shell
I could be wrong in my assumptions, but the owners of 34 and 35 GTRs in the area give the impression to me that they're too good for SAU...moreso, they give no impression at all, because while I am 99% certain they know of the website and forums, they never post or reply to spotted's...
ah well, such is life.
Think you'll find there's a lot of Skyline owners of all sorts that aren't on the forums. I owned Skylines for 6 or 7 years before I signed up. Didn't think I was too good for the forums but just wasn't as into the whole car scene at the time.
You couldn't jump start it from the Audi or the daily?
Spotted a black R33 in the carpark opposite Mooseheads tonight.
I don't have the proper surge protector type cables to do it. I need to invest in a charger now that I don't drive it so often if I can't fix the slow drain that I have on the battery.
Spotted a purple R33 4 door yesterday at about 6:30 on Belconnen Way. Bodykit and wheels not really to my taste but the colour looks awesome!
you alco shell.. drinking at mooseheads and it was only wednesday night... tisk tisk
lol Mooseheads wasn't even open... i was at King Omalleys... and I'm still on holidays so :thumbsup:
Also yellow R34 turning left from Ashley drive onto Johnson yesterday arvo, was from a distance so I couldn't tell who was driving it, though I assume probably not shell :thumbsup:
What time? Could have been me... i went to Calwell shops around 5-5.30pm
spotted black R33 GTR with black rims and yellow decals. had ACT plates so i'm posting here.
Looked like a series 3. Saw it in Moss Vale around 3pm. I was in my FTO. Awesome looking car mate.
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
