Spotted!!
Shell
Yellow R33 southbound on north borne yesterday or the day before in the afternoon. White (mostly - black bonnet) R32 going past Dara at night and a white R34 heading towards Fyshwick on the Monaro hwy today.
Only saints I can think of are the New Orleans Saints who were in the Super Bowl....but now that I check wikipedia, I see you know about an indoor football team...lol Shell what DO you do with your spare time?
Actually the Utah Saints did a song called "Something good 08" which has an awesome videoclip, i suggest you look it up on youtube sometime.
yes that's what I'm talking about... well more the original from the 90's :P
I posted the youtube link in my post above, can neither of you see it??? :)
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
