Also spotted myself this morning dropping the 33 off at inline...can't wait to get her back on friday, gonna be a whole different car! especially considering the total damage to my wallet comes in at roughly $3700, it'd wanna be good! Who wants to go for a drive this saturday? lol
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5179586
it will be well worth it! mine gets finished on friday finally! what are you getting done to it?
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5180407
Spotted black 33 on drakeford drive this arvo at the erindale dr intersection. Gave a wave, got one back :D
haha that was me :D . I saw a burgundy(well lets say maroon) r33 outside of lanyon maccas around 1:00am this morning. May have been leaking something as it left a trail after it parked for a few . could have just been there already though not to sure.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181378
Can you let me know what you think of their work v costs/value for money. as i am considering Getting them to sort out some bits and bobs for my pulsar.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181937
I'd say many people here (ZCR, Turismo, GTRKat+many others) could vouch (and likely will) for Chris and the team's work at Inline - it's the main reason I've taken my car there. Of course I will post up results+thoughts once I'm done.
Only negative thing's I've heard about them is that you obviously pay proportionately for the work you're getting - meaning they're reputed as expensive but well worth it, and that Chris has a tendancy to go a little over the top, and have parts replaced that don't 100% need to be. That being said, if you're going to spend some money, and want good results, I've heard it's the right place.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181989
Thats cool
Plan is to replace Shitty and way too stiff D2's for TEIN in the Pulsar. Every other bush, link, brace, nut and bolt that can be changed has been done by a well known and trusted suspension shop in sydney. Appears the last owner ran out of coin when it came to the coilovers.
Well i will look forward to your feedback (and getting his quote).
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5182221
spotted a very menacing black R33 in Weedon Close at ~430 this arvo.. it was very black, super dark tint, nice body kit and gold GT-C rims.. looked fkn mint.. for a 33 :ninja:
also spotted a silver Stagea right after that next to Rubies turning into Weedon Close
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5182362
Spotted white 33 this morning parked across from Hyperdome on Anketell....License plate reads YFZ-33E
Why did I take note you ask? Well mine reads YFZ-33H
Coincidence? I think not! Conspiracy I say!!! Government is pulling some funny shit here on me.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5185706
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
    • Tapin,    So got mine up and realize a few things. First was my slave line doesn’t reach the other side, so I have to get a longer hose made. I want to ask did you have to extend your wires for the CD009 sensors? One on the driver side(right side of car looking at the car from the rear) and one on the passenger side( the left side of car from rear). And do you know what those two sensors are respectively? I know it’s not Speedo since we talked on this already. And I may have to separate the trans again to swap out throw out bearing. We will see. Did you run your RB slave cylinder? I know you cracked your original but replaced it with a nismo. But wasn’t sure if you bought the one designed for the CD009 or not. Thanks
    • There is X amount of load on a timing belt. Adding bigger duration cams and valve springs will certainly add some to that figure - but there is no way in creation that you need "300% stronger". There are plenty of big power RBs and JZs running stock belts. There have been more complaints about noise from Gates belts than there have been reports of stock belts dieing young.
