heading into civic on sat night about 9ish stopped next to at the lights of N/bourne and london cct, a white 70's C110 Skyline Coupe. Wound down the windows for a chat and found out the bloke has a RB25Det (not neo) pushing over 300rwkw! So he claimed... Looked real nice and sounded awesome. Was in the 34 so it woulda looked pretty cool crusin next to :)
https://www.sau.com.au/forums/topic/30059-spotted/page/620/#findComment-5210624
Think I came across this dude on Hindmarsh in weston....assuming the thing really didn't look that amazing, being that the paint was pretty meh etc.
If it's the same one, it was surely much more powerful than mine, but something tells me it was definitely not 300rwkw...unless he just didn't give it *that much*
https://www.sau.com.au/forums/topic/30059-spotted/page/620/#findComment-5210758
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
