Spotted a white 34 GTT this morning on Belconnen way turning in to Oconnor. I think I've seen the same one a few times now.
Oh and spotted that fricking foxtel ad at the top being very annoying! Not a fan of the rollover type ads!
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5228738
Back way through CSIRO to bypass traffic ftw.
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5229456
Spotted Silver R35 at like 1pm ish hitting some golf balls on Griffith ovals (no idea what they technically are)....I was one of the wanks playing soccer on the oval. f**k yeah lunchtime soccer!
Anyway, your bloody car was blinding me every time I looked at it - and believe me that was a LOT lol...very sexy!
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5230971
There was a Series 4 blue RX7 on the side of the Barton Highway this morning just near crace, in case anyones knows of anyone missing one. Horrible POS chrome wheels.
I also spotted a Maxima TI with get this a GT-R badge high and proud on the boot, I didn't think they made Maxima GT-R's?
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5241486
Hahaha seen that car. The guy is an idiot. Not only is it spotting a boot badge, it has gtr front quarter panel badges too. This person has gone to alot of effort to be a dumbass.
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5243389
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
