Spotted!!
Shell
trozzle have you sent the turbo back to hypergear? Ive seen a few of them and never really been very impressed with the quality especially when simple things like bolts are barely metalic or magnetic lol
garrett althe way my friend!
ive been spotting a few lines including a nice black on black 33 gtst in phillip there was also a very clean white 33 gtr at ESP Friday night and James at ESP today too haha
I'll be removing it and sending it back to be looked at.
He has enough customers with proven results to show that even the lower quality products still work without issues. The main problem at hand is that there's a very good chance that the wastegate issue I'm having was inadvertently caused by ESP when they dismantled the (admittedly dodgy) wastegate adapter plate and then put it back together for no apparent reason.
Either way, we'll know the issue once it's off, and I'm sure that Hypergear tend to warranty issues a lot better than Garrett would, or even be able to lol
bahahaha, now someone else knows where I live! First it was w1ngnut when I was at my parent's place, now you! lol
Don't spose you spotted me under the car swearing my head off?
I know where you live... :happy:
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
