Thanks :) Mick,
The Cayman ran up the back of a Commie which went up the back of a Suzuki which went into the back of Matt's R33 GT-R.
It looks like minor cosmetic damage only. Reo/bever panel will need replacement as well as the bar. So not too much.
Matt will probably be offloading the GT-R soon, as he's buying my R34 GT-R. I'm committing myself to a Bayside Blue VS2.
Nissans are under my skin a bit more than Matt, as he's still quite keen on Beemers too.
What comments (criticisms as well as compliments) did your boys have about the 21st? Different hairstyles back in the early 90s eh?
The new toy sounds very nice Terry, and Matt is a lucky bugger to be getting his hands on your R34 GT-R (I am jealous).
The boys were very impressed how the R32s were untouchable at Bathurst in 91 and 92.
They had a great time at the 21st being around all those JDM Skylines, and very much enjoyed the cruise and want to do another soon. Ben is putting awide body kit on the Silvia, so will look quite different shortly. They (boys) are trying to convince me to sell the GTT and move up to a R34 GT-R (not much convincing required there I'll tell ya)....soon....soon.
https://www.sau.com.au/forums/topic/30059-spotted/page/639/#findComment-5516444
rofl yes I think so. Looks funneh.
I've also seen a bright orange 33 getting around tuggers area with some blonde chick driving...hmm
Also spotted a black (?) 33 headed south on drakeford yesterday pulling up to the roundabout at isabelle drive...gave a wave and got one back :)
https://www.sau.com.au/forums/topic/30059-spotted/page/639/#findComment-5520033
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
