Spotted!!
Shell
I'm sorry ... I should intro myself,
My names Bill, I've been a Skyline fan for many years and have owned them for 10 years having a gunmetal S1 R33 before the 34. I moved to this area abot 3 years ago and have been a regular 'guest' to this site to keep an eye on whats happening around the ACT.
I couldn't resist Zebra's post so I registered and said hi, I've seen many of you on the road in my travels, my work keeps me running around town a bit so you'll probably see the car around. As I said I usually give a wave if I see you early enough. B..
Nice to meet you.
A few guys meet on Friday nights (see the Friday night not at museum thread) I havent been out cause Im generally drunk and asleep by that time but I'm gonna try and make it out this week.
hahaha yeah a compliment!! I'm not really good at thieving :blink:
I really want dark bronze rims, they'd look wicked with the yellow :)
They would Shell, bronze was made to go with yellow, mine as I said was done by Wicked Wheels and when in the sun (and clean) they have a gold fleck through the bronze ...
I'm torn between getting mine resprayed (and having the gutter rash fked off lol)
Could only really get them done black....white R33 GT-R wheels would like ghey.
I wouldn't mind a set of those multi spoke fluoro yellow wheels in 18 though.... :D
Nah, sell 'em and buy mine :-D
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
