Spotted!!
Shell
From someone with black wheels, they're awesome............never have to clean them! :D
From someone with white pain in the ass to clean Sparcos (that do look fabulous when clean) I'm quite jealous of these dark coloured wheels!!!
Brake Dust = Track day warrior street cred though lol
How about this. I get a quote to have mine resprayed/touched up. We'll pretend it's gonna be $500. Then I see how much I could see mine for. We'll pretend this is $1100. I don't want to be out of pocket more than $1000 lol, so we'll say my offer for your wheels would be $2100.
I'm breaking your balls here :D
Send them to Craved to get power coated :P
Where are they? Sending wheels somewhere is a bit...yeah...given it's my daily driver so not only would I be without them for a while, but I can't even take them somewhere once I don't have a car to drive lol
Brake dust on my wheels makes them look like they are supposed to be shadow chrome.. and when you clean them its like woah that is what chrome is supposed to look like.. Ajax window clearner is the best chrome cleaner ;) I'm thinking of getting the chrome taken off mine and powdercoating them gunmetal gray.. I think it would look awesome!! Is there a place in Canberra that can do that sort of thing?
Spotted a silver R34 GTT with a carbon/fibre glass bonnet and silver wheels in belconnen yesterday arvo around 6 at the lights on Southern Cross Drive and Coulter Drive. He was turning North down Coulter Drive. I see it a fair bit in the Belconnen area, it looks tough!!
Saturday morning all in Qbn
Black series 1 R33, tidy (woolies carpark
black R33 with carbon bonnet in the country energy carpark (nice looking car :D )
White R34 GTT in the other section of the Country energy carpark - very neat and tidy :down:
this morning, the Silver R32 GTR with N1 kit and TE's heading into QBN from the airport direction, very nice :(:) :)
pleasing to see so many in my area.
spotted a white r34 gtt with that big spoiler on the back in woden (nissan altia kit or something :s ?)
also a maroon r33 down here on the south side
and a silver r32 gtr (v-spec ii I think) parked in a driveway not far from my house... very nice car
Nah, dont own a skyline anymore, was in the Soarer
Ahhhhhh .... the black or dark coloured one? I got ya, I would have given you a wave but I'm not accustomed to waving to Soarers icon3.gif it's not something that comes naturally it has to be learned!!
Blonde and off topic I know but Zebra your "real name" just confuseed the hell out of me I was reading it and trying to say it then went hey, thats not his real name and then read it backwards and it all made sense :)
A soarer like yours flashed me last Saturday to let me in a gap..... saw blonde hair in the passenger seat and assumed it was you and Prue, gave a massive wave.... turns out it was just randoms LOL
That happens to me alot shell.. i see a skyline and go "that looks like so and so of SAU" then do a massive wave.. usually the only thing i get in return is a blank look as the driver tries to work out why someone in a 'hotted up' avalon is waving at them.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
