Spotted!!
Shell
Black 33 on Monaro Highway about 8.00 this morning around Michelago flashed headlights, apologies I was too distracted to wave in time, dark R32 GTR? in my mirrors on Parkes way around 11.45 am, I was in the Blue R32 GTR with the trade plate on the back, silver R32 on William Hovell drive around 10.00ish heading into City.
There were Skylines everywhere today.
Spotted a purple R32 with sparkly paint near Canb Hospital... waved but I think he thought I was a tool (he'd be right, but that's not the point)
Also another yellow R34 near Mawson yay!!!
Also saw a yellow 34 driven by a bloke this morn about 7.30 all the way down the parkway.
Not as good looking as yours Shell. Had a stock front/rear bar. Driven like Nanna does...
Yeh i loves my kit!!! so much sexier
Spotted a yellow R-34 GT-T in Erindale today. Wasn't Shell unless she's had an op recently :P
soooo... there's something I need to tell you :unsure:
haha nah I was in Sydney anyway
Cruised down southern cross drive with a maroon R33.
Also I always seen a white R34 crusing around Holt, up near where the Molonglo river is
I think i spotted you at the lights of SXD and Kingsford. westbound i was turning right and you were going straight? Around maybe 3ish?
I was a in the missus car...
I think i know the white 34 you're talking about. I've folllowed it all the way along william hovell and up into holt.
Went for my night run last night and was running along the Barton Highway towards the city and seen a very tidy yellow R34 GTT with a blonde lady inside. Nice car!
That would have been me on my way back from Sydney! Yay spotted!! :D
White R34 with a nismo wing turning off gungahlin drive onto sandford street (mitchell). Was three cars behind in a black 32 gts-t.
White 33 out the front of sign world in mitchell.
Also spotted a pink (i think? might have been purple?) r33 with a black bonnet cruising along william slim.
Edited by k_d
Spotted my car starting up again...took it for a drive with only the front pipe again to ensure all is well, but didn't get a chance to give it any due to it being late and the sheer VOLUME of the exhaust.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
