keep spotting the same greeny yellow r33 gts-t with a screamer pipe down south here around calwell/lanyon/gordon. not sure if you are a member on the forums here, but dude, you drive like a douche
+1 for this!
I've seen this car multiple times as I live in the Lanyon/Gordon/Calwell area as well and I dont think that the owner is on these forums... You're right though, he or she drives like a complete moron (giving the rest of us a bad name). :angry:
BTW - Spotted Jeno's old silver R33 Gtst in Fyshwick today, along with a black R33 Gtst with a rather large wing.
P.S - Why doesn't anyone wave anymore? I used to get waves all the time from fellow Skyliners but now I just get weird looks from other Skyline drivers :(
https://www.sau.com.au/forums/topic/30059-spotted/page/655/#findComment-5645743
Last time I waved I got looked at like I was a weirdo.... usually wait for them to go first now :P
Spotted a bayside blue R34 GTR parked near me at the Thunderdome. Hope none of the f**kers next to it gave it any carpark dings :( ... it looked pretty packed in.
https://www.sau.com.au/forums/topic/30059-spotted/page/655/#findComment-5645783
Spotted someone in a black skyline this arvo, don't think it's anyone who'd be a forum goer - more appeared as a douche, but get's respect for giving a nice smile and wave back.
Hoping that wasn't me. I was out and about in mine today, but dont recall waving to you... When and where was this?
https://www.sau.com.au/forums/topic/30059-spotted/page/655/#findComment-5646964
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
