Spotted!!
Shell
Maroon r32 GTR at the set of lights next to bunnings in fyshwick today. Cant remember the plates but were something like ***-GTR
Also, i keep seeing the white r33 GTS out the front of signworld in mitchell, has a SAU sticker on it so im guessing its someone on here?
spotted silver r32 with black bonnett on drake brockman at around 5:30, pretty nice
Tis Gun Grey bonnet not black... Pretty nice pfft it's a sexy car :banana:
*I may or may not have a biased opinion
i was driving the work van, big fat hyundai iload.
With working paying for fuel its quite alot cheaper than driving my whale around
And Sorry Melly, but i only caught a glimpse of the bonnet in the rear view as he turned off, i'll try and be more accurate next time :D
Black R33 GTST on Federal highway this morning followed by a cement truck turning the corner from Barton Highway which then tipped over. Crazy shit!
hopefully the cement truck driver is ok..........that being said that would have be hilarious to see
I don't think watching other people have accidents is hilarious. Had he been on the inside lane and there been a car on the other side things could have been much uglier. The lights went green and about 5 cars had already stopped. It looked like he'd already kicked the windscreen out and people were helping him out at the time so from what I could see he looked ok.
Stupid mistake but I imagine he's going to get in plenty of poo from his employer and a nice neg driving or equivalent for his troubles.
I'm sad that I never get spotted on my 3 minute drive to work each day! :(
Know the feeling. I drive around on the weekends and to and from civic each Tues and Thurs Evening, never get spotted either.. Been taking the old car the 10mins to work, so it is parked and exposed to attention.
Spotted a very nice 32GTR - gunmettal, white & silver wheels, black n white ACT plates, no wing ... going past the Qbn showgrounds and turning into Cooma St, if you read this, the car is a credit to you mate, very nice.
I forgot from Friday.... spotted cruising the main drag of the Hyper D (yes srsly), 2 Ferrari's, one white convertible and one deep red/cherry one. f**k they looked good. I'm not sure what model.
Also spotted a guy in a Corolla today wearing driving gloves :huh: Like, he had a tshirt, cap, sunnies.... and black leather gloves WTF
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
