Spotted!!
Shell
haha true.
today about 1 i saw a white R34GTT pulling on the drakeford from tuggers
and about 3 i was behind another GTT but silver pulling into kambah
Spotted that very very nice black R34 at the Drakeford Dr and Isabella Dr roundabout yesterday around 1600 or so. I was in the ugly duckling though and following my brothers on their bikes.
Different Pat lol
haha yeah i did actually, are you mates with him?
Yeah kinda, I know him through my missus. Nice car that blue one, I prefer it over his new one.
Edited by k_d
Different Pat lol
less of a cop magnet? haha, apparently he's already selling the new one too..
Spotted and waved at a cool Black R33 For sale... Well I had fun with you on Athlon Drive yesterday afternoon...
at least you smiled and gave me a wink... You left me for dead at the traffic lights, but i sorta let you,hehee...
but eventually caught up to you..Had fun, see ya around..Oh yeah I was the blonde in the white R33 GTS..xxx
ummm, lol yeah snap. At least you weren't admitting to racing yourself, only showing what kind of penis the driver of the black R33 is. As Zeb said, we don't like people adding to the already negative reputation we have been given for no fault of our own.
I'll be keeping my eye open for a wanker driving a black R33 that's for sale...
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
