Spotted!!
Shell
white r33 gtst at woden with GTR alloys and GTR style wing. then on the way home saw a black R34 with some kinda kit with carbon look diffusers hanging off all around it and possibly a mines badge on the grill, i rated it
I saw you Bill on say morning on Canberra ave or what ever its calling in Queanbeyan near the cop shop going the other direction to me.
Hi Mate,
I must have missed you on Sat morning .. sorry, but have you got the white Stagea? I see a white one around a bit.
Maroon (or maybe red? i dunno its dark haha) r32 in traffic heading along william slim towards the barton highway roundabout about 15mins ago.
Who owns the blue r34 gtr, driving to civic along commonwealth ave at around 12.30 today?
female driver. I was gonna chuck a wave but it would have been kinda awkward as my hand would have been far out my window.
Nice clean car btw
Spotted an LM Blue R33 GTR with what looked like black Work Meister S1's yesterday morning... I know that it's someone on here but I cant remember who.
That's one sexy R33 you have there! :)
A few mornings over the last week heading down the express way to the city I spot my car in front of me :unsure:
Due to slow "dream boat" public servants :angry: hogging both lanes @ a snails pace we dont get the chance to pull alongside and wave gday.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
