Spotted!!
Shell
Spotted a Black 34 GTT (With Battle Damage) maybe Bratva... last night around 9:15ish heading south at the Glenlock Interchange.
Everyone stares at my damage probably thinking i drifted into a tree or something. Jimmy i was waving frantically at you but you never look to your side thought u ignoring me! SHoulda stuck side by side for mini skyline cruise
Yeah I saw the crash thread didn't see you waving though.
Aside from the damage it's a nice skyrine.. Saw ya mate in the passenger seat having a look through but when I drove past you on the inside lane I couldn't see past ya hoodie :D
Next time i see you (side by side in our lines) stick around for a bit :)
I swear most people stare at the dent and they stick their heads out the windows to try to 'show' you that they are aware of the damage kind of like being smart arses with their exagerations. Maybe i need to take my p plates off they make me look like a hoon
Hi Kat
I don't get out that way often (especially in those little back streets) but for a three generation photo opportunity I will be happy to come out anytime ,, count me in. BTW .. I did admire your 32 some time ago when it was in Craig Halls, I frequent there for servicing etc.
Ahhhh I see. Mine sneaks out there occasionally. I work with the owner of the white 33 :)
Hehe need to all park next to each other.
Should organise Dave to wash his car (and I'll do the same) and we should go take some piccies some time with the whities!
Thanks! That was ages ago (it's only been there once) and she's a fair bit different now! :)
I'm heading off for a drive up the Putty, through the Hunter Valley and onto Tamworth, just feel like hitting the road for a few days .... mine will need a wash when I get back.
Let me know when you guys a ready for the pic's, mine doesn't often get to meet 'the family' ..
Edited by THE34T
yeah Ill stick around for a cruise next time. I'm normally there at that time on mon, tues, and wed, after I leave CIT.
And yeah that's cause most people are idiots...
Also, P plates don't belong on a car like that.. Not If you wanna keep your license..
Oooohhhh, i dont suppose your at the reid one? Thought i might have seen you car there the other day, but i dunno...
I drive the black 32 with an undercoated bonnet :P
Do you go to the Bruce one because I think I saw your car last night when I was at my night class.
Spotted a black Stag drive past my work this afternoon.
where you working? my gf had the car at tuggers today?
also @jimmy, nice avatar, i love the castle of cagliostro.
Nah man, i'm at bruce, but my little sis is at the reid one and i've picked her up from there a few times.
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
