Spotted!!
Shell
Spotted melly yesterday morning in fyshwick and someone exchanged waves with the missus in a black r33 with dark rims. Also spotted new adjustable castor arms and rear camber arms in my stagea on Saturday.
Sorry I don't think I noticed you hasn't been a real good couple of days so I would have been like urrgh other cars...
ZCR I was on like 6 dollars when I was 20 as a first year not I'm 21 and second the pay is fu*king good lol
Jimmy
Yea it was so boring went for like 3/4 hours :(
And yea inductions suck haha it's all over now
Spotted Subaru driver rear ending my car at a set of traffic lights. 7 years of hard work to not just buy this car, but keep it running, insure it, modify it and respect it, ruined by 2 seconds of incompetence by some guy who must have been playing with himself at the time not to notice it stopped. Not. Happy.
Fingers crossed. Just hoping the insurer doesn't decide to write it off. Pretty sure my insurer gives me a choice of repairer, any suggestions in Canberra? Last place I took my other car too has closed down, Gemini i think it was.
Good luck mate.
FYI
Gemini still operates.. they're in fyshwick and mitchell
Mucho improvement ????
Yeh heaps, for starters im not running -3 degrees camber in the rear with eccentric adjuster maxed out and eating tyres. I can now get the rear lower without fouling the coilovers too. The castor arms I didn't go too crazy with castor but it corners very well and hard braking feels more direct and pedal seems stiffer cos there's zero play in the front wheels now (pillowball arms).
spotted a black stag on mugga way at 8:09 haha looked nice as also saw a black 34 gtt with black rims in civic around 4:430
Woulda been my missus driving to symonston this morning. Cheers
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
