Spotted!!
Shell
THE-34T on Northbourne Ave 10am, gave a wave but I'm in the work van so if you saw me undoubtedly you were wondering who the fk I am haha
Hi Trozzle, were you behind me in a white van? I did sorta catch something going on out of the corner of my eye ... regardless, thanks for the wave mate.
Yeah white Hyundai iLoad :P did a bit of lane dancing to get in front of you where I think I gave you a wave as you went past me on the right.
yes - was sin at ESP
Today the boost was raised from 18 to 21psi
Result from 326kws to 350kws on Dyno Dynamics dyno.
Strong build from CRD and great tune from Glen
Runs out of puff past that.Garret 2860-7's
To correct any potential misinterpretation this is 350 rwkws
awkws is 326. Overall speed is the same but getting there is quicker.
A nice fat curve and acceleration is very linear.
Not a throw you back in the seat blast you get with the big singles when they come on song.
lol :P
Also Richard, you should make pretty much the same power on a 4WD dyno. There's been many a shitstorm argument in Forced Induction section regarding rwkw/awkw and it's more or less decided that awkw and rwkw will be barely different, especially due to the way ATTESSA works.
Spotted a (stationary) silver R33 on what looks like 19s with a space saver front right lol
also spotted myself dropping car off for engineer's certificate. This is going to be f**king expensive.
A $4 hooker feels great.!
So I spotted today my nistune chip showing up
Also tomorrow I shall spot a courier with my SS1PU
We we we so excited we so excited all the way home
It's Friday Friday gotta get down on Friday
For 4 bucks - you'd be lucky to cop a quick feel - although there is always Qbyn gals
Good luck with NIStune and stuff.
Should see 260-280kw with the 2835 Pro S
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
