Spotted Trozzle's car parked on the road out the front of Gentech in mitchell yesterday arvo
Yerp, was getting engineer's certificate at Canberra Motor Works. Unfortunately didn't get it due to a few things (one of which is worrying lol), however shouldn't be hard to fix up. Unfortunately I foresee having to cancel the rego on my car before the lack of defect clearance does it.
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250315
Something to do with the diff/cradle mounts is allowing the whole diff to move up/down around 10mm
Yeah you're right.. just a little worrying :/
Spotted Troy and Richard hugging each other as the sun went down over the lake. They looked to be eating takeaway.
Hope you boys had fun
Sin and his troy boy
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250393
Batted Savs with Mayo & Choc tipped Bannanas, your Favourites. You should've come............
Gags :sick:
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250489
Cheers Josh!
Yours had a nice tune when it took off as well
I spotted a r31 parked outside of Pedders in Phillip as I dropped my car off for an inspection
Spoke to the guy who owns it about his Rims dont know if his online here
Also spotted a Silver 33 cruising around Phillip.
Then Josh rocked up for a surprise visit just after I talked to Natrad about my constant coolant problems
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253128
Pedders bad :down:
Rear calipers installed on wrong side and upside down. Pads on wrong way in calipers.
All new suspension installed but not adjusted. Camber out, toe out, F/R balance alignement out.
Bled in wrong order, air in brake system. Did not and would not blead ABS - WTF.
3 x returned for fixing - no luck and they had no idea.
Sir your brand new Rotors/Calipers/Pads/braided brake lines/BMC have no problems. Your car just does not stop very well and its got very spongey brakes. You should look on the internet and see what you can do to fix that !!!!!
Yes I went back and told them what was wrong and that I had paid again to have it done.
1 minute at ACT brakes - your calipers are on upside down and wrong side sir. Fixed. Felt alot better.
But these guys didnt notice pads installed correctly. Went back twice more. Sir there is nothing more we can do !!
Both of the above shops have "Brake Specialists" in their business name.
ESP identified and resolved all brake issues :thumbsup: and bled the ABS as per what you are supposed to do !
Capital steering and suspension for dialing in suspension :thumbsup: . Booked in Wednesday.
I should go get the spare key to my car and go steal it back haha?
Okay well there goes $14 for the inspection lets see what they come up with that's wrong with my car
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253190
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
