Spotted Trozzle's car parked on the road out the front of Gentech in mitchell yesterday arvo
Yerp, was getting engineer's certificate at Canberra Motor Works. Unfortunately didn't get it due to a few things (one of which is worrying lol), however shouldn't be hard to fix up. Unfortunately I foresee having to cancel the rego on my car before the lack of defect clearance does it.
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250315
Something to do with the diff/cradle mounts is allowing the whole diff to move up/down around 10mm
Yeah you're right.. just a little worrying :/
Spotted Troy and Richard hugging each other as the sun went down over the lake. They looked to be eating takeaway.
Hope you boys had fun
Sin and his troy boy
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250393
Batted Savs with Mayo & Choc tipped Bannanas, your Favourites. You should've come............
Gags :sick:
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250489
Cheers Josh!
Yours had a nice tune when it took off as well
I spotted a r31 parked outside of Pedders in Phillip as I dropped my car off for an inspection
Spoke to the guy who owns it about his Rims dont know if his online here
Also spotted a Silver 33 cruising around Phillip.
Then Josh rocked up for a surprise visit just after I talked to Natrad about my constant coolant problems
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253128
Pedders bad :down:
Rear calipers installed on wrong side and upside down. Pads on wrong way in calipers.
All new suspension installed but not adjusted. Camber out, toe out, F/R balance alignement out.
Bled in wrong order, air in brake system. Did not and would not blead ABS - WTF.
3 x returned for fixing - no luck and they had no idea.
Sir your brand new Rotors/Calipers/Pads/braided brake lines/BMC have no problems. Your car just does not stop very well and its got very spongey brakes. You should look on the internet and see what you can do to fix that !!!!!
Yes I went back and told them what was wrong and that I had paid again to have it done.
1 minute at ACT brakes - your calipers are on upside down and wrong side sir. Fixed. Felt alot better.
But these guys didnt notice pads installed correctly. Went back twice more. Sir there is nothing more we can do !!
Both of the above shops have "Brake Specialists" in their business name.
ESP identified and resolved all brake issues :thumbsup: and bled the ABS as per what you are supposed to do !
Capital steering and suspension for dialing in suspension :thumbsup: . Booked in Wednesday.
I should go get the spare key to my car and go steal it back haha?
Okay well there goes $14 for the inspection lets see what they come up with that's wrong with my car
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253190
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
