Spotted Trozzle's car parked on the road out the front of Gentech in mitchell yesterday arvo
Yerp, was getting engineer's certificate at Canberra Motor Works. Unfortunately didn't get it due to a few things (one of which is worrying lol), however shouldn't be hard to fix up. Unfortunately I foresee having to cancel the rego on my car before the lack of defect clearance does it.
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250315
Something to do with the diff/cradle mounts is allowing the whole diff to move up/down around 10mm
Yeah you're right.. just a little worrying :/
Spotted Troy and Richard hugging each other as the sun went down over the lake. They looked to be eating takeaway.
Hope you boys had fun
Sin and his troy boy
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250393
Batted Savs with Mayo & Choc tipped Bannanas, your Favourites. You should've come............
Gags :sick:
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250489
Cheers Josh!
Yours had a nice tune when it took off as well
I spotted a r31 parked outside of Pedders in Phillip as I dropped my car off for an inspection
Spoke to the guy who owns it about his Rims dont know if his online here
Also spotted a Silver 33 cruising around Phillip.
Then Josh rocked up for a surprise visit just after I talked to Natrad about my constant coolant problems
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253128
Pedders bad :down:
Rear calipers installed on wrong side and upside down. Pads on wrong way in calipers.
All new suspension installed but not adjusted. Camber out, toe out, F/R balance alignement out.
Bled in wrong order, air in brake system. Did not and would not blead ABS - WTF.
3 x returned for fixing - no luck and they had no idea.
Sir your brand new Rotors/Calipers/Pads/braided brake lines/BMC have no problems. Your car just does not stop very well and its got very spongey brakes. You should look on the internet and see what you can do to fix that !!!!!
Yes I went back and told them what was wrong and that I had paid again to have it done.
1 minute at ACT brakes - your calipers are on upside down and wrong side sir. Fixed. Felt alot better.
But these guys didnt notice pads installed correctly. Went back twice more. Sir there is nothing more we can do !!
Both of the above shops have "Brake Specialists" in their business name.
ESP identified and resolved all brake issues :thumbsup: and bled the ABS as per what you are supposed to do !
Capital steering and suspension for dialing in suspension :thumbsup: . Booked in Wednesday.
I should go get the spare key to my car and go steal it back haha?
Okay well there goes $14 for the inspection lets see what they come up with that's wrong with my car
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253190
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
