I spotted a 32 GTR turn off just after the bridge near parliament house.
I managed to drive over the bridge just in time to hear him open it up as he went under.
Also a 33 could have been a GTR as it had the wing. Also had forsale sign. At the roundabout turning on to gunderoo drive
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6321434
spotted a silver R32 4 door in narrabundah that appeared to have plexiglass windows and he was having a bit of fun showing off. I also spotted a black R32 gtr on hindmarsh drive along with a yellow R34 gt-t going the opposite way around 1:30
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6324562
showing off how?
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325528
Showing off by letting
Your mate take ur car for a spin without u in the car...last time I let him drive.
I just spotted a silver r33 gtr on hindmarsh dr was gunna wave but was in my bogan spec commodore did enjoy watching it race a black z06 corvette pretty sure the corvette didn't catch the gtr either which is always a good outcome
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325671
Hmm 4 doors seem to be sprouting in Canberra. Spotted shell near kambah caltex servo around 540 . PS your front left headlight doesn't work. We were in the Kia.
haha yeah I know... put some new globes in and now the earth wire thingy has fallen out and won't go back in. Bought some little electrical things and r32-25t is going to fix it for me tonight.
I don't remember seeing a Kia, but then again I wouldn't really have been looking :P
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6325771
Delayed spotted: went to the movies on Monday night in Woden. Saw a neat white 32 GTR. When we came out, it was warming up; I wanted to go up and say props but figured I'd look like an old man weirdo stalker, LOL!
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6329888
Pretty sure It's the same one but it's always there.
Parked out the front of the shops
Doesn't seem to be anyone on here
https://www.sau.com.au/forums/topic/30059-spotted/page/735/#findComment-6330024
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
