Spotted!!
Shell
Saw a black 31(mighta been a 30...I'm getting a bit rusty in my old age)on the Monaro about 45 mins ago. Sounded very well sorted, and had custom plates something like 'BOOSTN'? Anyone on here? I'd like to know more about that car...
(unfortunately DIDN'T spot) some dream boats smashing my van's driver's side mirror this evening. In the 40 minutes or so it was parked on the street someone has decided to smash the mirror off....here's hoping VW don't charge some hilarious amount of money to fix it...kents.
Saw that one yesterday Jayce - just can't remeber where but we exchanged waves.
Spotted a wingless orange 33 and a gunmetal 32 at the lights on Athlon :D
The gunmetal 32 was my non turbs daily driver sin, must have missed you though. Saw both the silver 33 GT-R and the Orange 33.
May have been me...What time was it about?
umm...maybe 5:15 or thereabouts? Can't remember haha, I was in the bright orange van next to you on Athllon.
Was probably me. Just picked the car up from Ultimate Tunes and was on the way home around then.
Spotted same maroon R32 GTR on Athalon Dr. this evening at about 1800. Got a wave. It sounded nice.
If your on here I was in the silver R33 GTR. You were behind me coming up through Bonython.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
