Spotted a silver S15 and a skyline (sorry I can't remember what it was.. white from memory lol) that seemed to be together on Athlon Drive on Friday arvo.
Also spoke briefly to a guy in a red R32 at the CTSR cruise last night (on idea if he's on here). Was also a white R33 with gold rims there.
https://www.sau.com.au/forums/topic/30059-spotted/page/771/#findComment-6607835
Spottin' Sundae.
Saw a stock looking Pearlish White 4door R34 GT in the Bunnings carpark in Belco 4:20pm. No Fear sticker on rear bumper and 2 rabbit ears type antennae on either side of rear window.
Silver Series 2 R33 at Kippax shops, female driver with kid in front seat 6:40pm.
Silver S15 with Carbon Bonnet also in Kippax carpark 6:40pm.
Also 6:40pm the other Series 2 R33 which is always parked up in the top carpark at Kippax shops.
Edited by Not a Pulsar
https://www.sau.com.au/forums/topic/30059-spotted/page/771/#findComment-6608795
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
