Spotted Kat in the GTR around 12.30! on teh end of the Monaro!
Yay spotted!!! What were you in??
I spotted a white R34 on the way home going past the airport. I forgot to wave cause I got so excited I was in the GTR and someone else waved at me!! LOL :)
https://www.sau.com.au/forums/topic/30059-spotted/page/776/#findComment-6632212
i was in the stagea but was kinda behind a bush driving the other way!
https://www.sau.com.au/forums/topic/30059-spotted/page/776/#findComment-6632649
Yep pretty sure that was me Kat ... And yes for once I did get a chance to wave ... Nice to meet you.
Btw ... The GTR looked very nice
Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/776/#findComment-6632828
    • Thanks for advice chaps   so you would change idler and tensioner bolt as well ? I guess because you thinking they have stretched once ?   i have done some research and on nissan belt and seem to hold 700hp but thinking HKS to be on safe side   i think I put nissan there last time   also thinking of changing cam cover to glass style:)
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
