I knew I should have waved at that dude on the pushy!! ... Lol
Thanks mate, at least you didn't kick my door ..
Didn't even notice it was YOU until you drove off up Uriarra rd or whatever it is, and I saw your rear number plate (since I don't believe you had one on the front :P), otherwise I would've waved and confused you haha
https://www.sau.com.au/forums/topic/30059-spotted/page/852/#findComment-6924142
Saw this nob head of an nob head this morning. Hooning, Swerving, Tailgating, Racing and being a general nob to the general public. Licence plate AJC (Custom Black) and by gosh he had the nerve to look at me and shake his head whilst over taking me and then “flex” (accelerate hard) and his 4 cyl hatch Subaru sounds like a broken down lancer. GRRR
spotted maroon R33 yesterday
https://www.sau.com.au/forums/topic/30059-spotted/page/852/#findComment-6924215
Struth i hope I got one on the front .... Better check that out .... Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/852/#findComment-6925118
Spotted a BB r34 GTR and a black R35 next to each other near the city, i think its an ANU building not sure. Was around 4.30
Both Brothers - they live couple houses down from me. The R34 owner is quite nice - the R35 guy didn't seem to impress about my stalking eyes.
https://www.sau.com.au/forums/topic/30059-spotted/page/852/#findComment-6926142
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
