I think John's cousin or nephew owns Troy's now.
Sounds like it was basically a new car by the time they fixed everything.
Must be nice to have the contacts etc... :/
Same white Stag with black bumper at Mitchell Jax again today too.
What is it with Jax Employees and StageAs? :laugh:
(waits for Taylor to pop up.)
https://www.sau.com.au/forums/topic/30059-spotted/page/863/#findComment-6971939
theres two there and one is been built to make 400watts at wheels old dudes car very nice bloke, other one is a drag car not too sure about it
i think its a drag car i looked inside the interior and it has those 3 gear drag thingys lol
https://www.sau.com.au/forums/topic/30059-spotted/page/863/#findComment-6972971
Lime green wingless R32, followed by a silver R33 GTR on Athllon Drive near Red Rooster a couple of hours ago.
I spotted a lime green wingless 32 the other day on Canberra Ave .. Did he have a 'P' plate blowing in the breeze under the back?
https://www.sau.com.au/forums/topic/30059-spotted/page/863/#findComment-6973666
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
