i take my hat off to you troy. Having broke your back and getting back on a bike a risking it again. You got some bawlz brah.
Perhaps NOW it's balls, but initially anything remotely risky I did after breaking my back was purely out of ignorance and arrogance ;) was back in the gym 4 days after doing it LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7096061
:unsure:
Yeah that's about right :P did I mention I didn't even get an x-ray done until 18 weeks after the incident? Yeah, I'm awesome.
Bro do you even deadlift.
Very rarely now lol thanks to developing an issue with my SIJ....but I went on to pull 172.5k @73kg
I've switched to sumo stance recently which has alleviated that problem almost entirely, so just gotta get back to doing them consistently I guess
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7096134
If anyone would like a prestige body such as mine - let me know and I'll give you my workout routine and sound tracks.
hahahaha love the soundtrack bit :P
Hence why I bought this the other week - can hit every muscle group without a worry, and obviously no worries at all with the primary lifts.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7096472
Nice i wish i had that. Do clean and jerks too they're just amazing.
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7097069
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
